ferhankov
So a little problem shown in the photo. The bracket's bottom slot for the nut/bolt is clashing with the frame. Is the bracket supposed to sit on top of the frame, or am I supposed to drill into the frame or what?
Easiest way would be to slot the holes a little bit. Or cut the brackets off and reweld. Or take it apart and dent the frame right there. Some will say don't dent the frame, but dents are stronger than holes, and don't let water and stuff in to rust your frame from the inside.
