Rear axel sheared off - how to repair?
jmandawg
Hi,
I have an older kart with a single drive wheel, my daughter was riding it tonight and the axel sheared off, looks like it was a bad bearing maybe.
Sad thing is i just changed all the bearings except for that one because i was waiting for the tire to wear down.
So any ideas how to fix it? Just cut it off and weld a new one on? I only have a small Harbor Freight 90Amp welder, would it be strong enough to weld it on (all the torque is on that wheel)? Also where would I buy the 5/8" threaded bar?
Thanks
kenworth85
Grouchy old man
Blanchard Oklahoma
Use a grade 8 5/8 bolt weld it on head and all. Look real close, it seems to have bolt head welded to the square tubing. I would think your welder will work with proper prep to the axle and bolt.
You'll have to cut the head off of the broken one on the frame.
The new bolt head will need to have a bevel ground on all corners of the flat of the hex, this allows the best penetration.
Clean all paint off of the boss where the bolt is to be welded to. Tack and weld(need to brush good in-between tacking and welding, dont just go over it.....).
Atlanta, GA
To weld that with your welder, you'll have to get everything heated up (till it's blue) with a torch, otherwise you will not get enough penetration.
anickode
S.E. Michigan
Also, when welding a grade 8 bolt, no NOT get impatient and quench it to cool it down. Grade 8 bolts are a high alloy steel, and it will get very brittle if you quench them.
jmandawg
That's what I was afraid of. Do you think the 170amp HF welder would be strong enough? I may get that and sell the 90amp. Or do you think i can get it hot enough with my propane torch before welding?
Atlanta, GA
I've welded 1" axle stock to a 1/4" collar using my 90A, got full penetration. Propane torch, blued the whole component first.
