Re-jet?
Jake.B
California-USA
I Have a 5hp Briggs and stratton. I put racing valve springs and a header. I'm planing on buying an aftermarket clamp on air filter to increase air flow. ( link below ) Will i need to re-jet? Im thinking i will, but just wanted some opinions. The only reason im asking is because im on a tight budget and i need other things for the cart to actually move, A.K.A wheels. If so what is the stock main jet? What do you guys think the jet size will need to be increased to?
http://www.amazon.com/Uni-2-Stage-A..._5?s=automotive&ie=UTF8&qid=1328157193&sr=1-5
fowler
Bullsbrook West Aus
it doesnt always
somtimes it manges just fine
if u need to rejet u can get some tiny drill bits to drill it out a size at a time if u not what to get a new one
although they are probs a $1 or less (iv never tryed to buy them)
FlatFootRacing
Speed Freak
Easley, SC
What type af carb do you have! does it look like this:
Does it have the fuel adjustment screw on the side or does it have a welch plug over the jet?
Jake.B
California-USA
It is the pulse jet carb i belive. it maches the one the one in the photo. I will have to get back to you on the fuel adjustment screw. Is it just a needle you can turn into the jet?
