RE. Honda gx160 help!!?
Dazv
England
Hi guys, I've just changed the drive shaft in my honda hx160 without any problems using advice from here. Anyway I've just gone to try to start it and nothing happens! Was really really well before but nothing is happening! Any ideas guys?
Thanks so much
Darren
Dazv
England
Hi mate, yep the dots are lined up and the engine turns over just fine but doesn't fire. I took the carb off and drained it which didn't help. Any ideas? Thanks for the quick reply!
Have you made sure that you are getting spark? Pour a teaspoon of fuel down the spark plug hole, put the plug back and pull. Did the engine run for a second or two?
You can also test for spark by taking the plug out, putting it back in the plug boot, holding the plug end against the block and pulling the cord. Did you see a blue spark on the end of the plug. You can also hold the plug end in your hand while you do it. If you get a shock, it is getting spark :D
Dazv
England
Thanks again for the quick reply! I just put some file down the hole gave it Afew pulls but it didn't run or fire up. There is a spark if I hold the end on the plug near the engine it jumps across but doesn't seem to spark if it's on it's own. It's so strange it was running just fine yesterday! Do you have any other thoughts? One thing that did happen when I changed the drive shaft was one of the two push pins(not sure of there name) fell out, all I did was put it straight back in.
You might find that your valve clearances are not correct anymore. You might have to reset them. Make sure that the piston is at Top Dead Center before doing the measurements and settings
Dazv
England
Yay! Well you were right about the valves! I took off the valve cover to see that the valve arms had slipped off the pins so it wasn't compressing the springs at the back. Put them back on and it fired up first pull a load of smoke and Afew bangs but then seemed to run just fine! Thanks so much for the advice it obviously helped haha. Right no to get her in my first kart!
No problem. I am glad i could help
