Re Design questions
jasper909
So i have decided to change my approach at a go kart engine and clutch system.
My old post was asking about a dirt bike set up, but i have scrapped the idea and have decided to go with a Harbour Freight 212cc engine and probably a jack shaft set up.
So on that note, I was hoping this forum can help a newbie out again :wai:
My first question would be gearing. I know the basic idea of a Jack Shaft having watch mainly T Mans videos on them, but i am unsure on the proper gears to use. I will most likely be going with 15in tires for off road and on road use. Im 220lbs and want a fast and torque filled go kart. I know you cant achieve the best performance with a jack shaft, but they are significantly cheaper than a torque converter :thumbsup:
My second is about the motor. Is it worth the $126 they are asking? Its cheap price wise but is it a good buy?
My third question is what clutch system would work best for the cheapest, if there is even different set ups?
Thanks for all of the info, and sorry if it has been asked before!
I want a fast and torque filled go kart. I know you cant achieve the best performance with a jack shaft, but they are significantly cheaper than a torque converter
Speed or torque, pick one. It's not impossible, but it's difficult to find a good balance; gear too high & you risk damaging your clutch, gear too low & you lose top speed. for the best of both worlds, a good ratio is around 6:1.
There's a significant difference between solid gearing (whether you use a jackshaft or not it's still solid gearing) & a CVT (torque converter).
- A jackshaft allows you more variation in the gearing but, once it's set, that's all you get.
- A CVT (Continuously Variable Transmission) changes the gearing as you ride (so to speak) so you do end up with the best of both worlds: good torque & a good top speed.
By the time you spend money on a shaft, bearings, sprockets, chains, etc plus the time to set it all up, why not just go for the CVT? you'll be happier in the long run...
Having no personal experience with these engines, the only comment I can make here is, I haven't heard any complaints
There's two basic setups; centrifugal clutch & cvt
Having said all that, why did you change your mind?
