So i have decided to change my approach at a go kart engine and clutch system.
My old post was asking about a dirt bike set up, but i have scrapped the idea and have decided to go with a Harbour Freight 212cc engine and probably a jack shaft set up.
So on that note, I was hoping this forum can help a newbie out again
My first question would be gearing. I know the basic idea of a Jack Shaft having watch mainly T Mans videos on them, but i am unsure on the proper gears to use. I will most likely be going with 15in tires for off road and on road use. Im 220lbs and want a fast and torque filled go kart. I know you cant achieve the best performance with a jack shaft, but they are significantly cheaper than a torque converter
My second is about the motor. Is it worth the $126 they are asking? Its cheap price wise but is it a good buy?
My third question is what clutch system would work best for the cheapest, if there is even different set ups?
Thanks for all of the info, and sorry if it has been asked before!
