Razor Electric (not anymore) 49cc 2 stroke Chopper
oscaryu1
Meh, might as well post it up :2guns:
With the help of Tyler resolved low idle and air leak issue.
Modifications:
Lightly ported/polished exhaust
Custom straight pipe (Definitely not for low-end power)
Adjustable 2 pad racing clutch
Stuffer Full Circle rankshaft
Ported/polished case and case transfers
Walbro WT-603 Clone Carburetor
Rockit 10 Degrees Advancement Key
Fibreglass Reeds
CNC Lightened and Balanced Flywheel
6/54 Gearing for Top End
WI_Chopper
full of ideas...
looks like the brass top can be screwed off with a wrench, then use a funnel? hard to get there with the handlebars
oscaryu1
otyq.
Yeah, I drilled out the CO2 tank. Works well, needs a better support though.
And needs a idler sprocket... so much vibration when acceleration the chain just spits itself off :(
(Chain' tight, but vibration causes the chain to shake literally 1-2" side to side)
mike75925
thinker and tinkerer
Alto, tx
oscar, you running liquid gasoline, or compressed gas? nice job, no doubt. ok i think i know what's up. you're using exhaust pressure to charge the tank and force the fuel to the carb. some of that r/c ingenuity hunh?
Innnnnnnnteresting!!! I didn't notice the second line at first glance. Is it working well? Does it work well enough for a fuel tank mounted BELOW the carb?
Re: Vibe's... Bent sprocket? Harleys vibe like nobody's business, and they don't throw chains...?
jr dragster T
Cold place
Its more of the clutch used on these 49 cc engines is very jittery when taking off and has a tendency to throw long 25 pitch chains.
oscaryu1
Fine ya hatorz, well I actually got it to stay on. I aligned the chain better, and it lasted great! Until I turned a slightly sharp turn.
Then she fell off, but I need some washers/spacers to make it work out some better.
It did gain a heckload of speed though, clutch is VERY weak. And very little torque. I'm thinking of swapping for that three shoe clutch now, two shoes can't haul my 145lbs.
