Razor dune buggy upgrade
Maximus
I’m new here but have been reading the forums for a while. I want to upgrade my sons razor dune buggy and before I pulled the trigger, wanted to know what others thought of the setup/what else you might get.
I was thinking about this lithium battery because I read someone else used Brett but after reading the sticky at the top on electric motors am open to anything
BtrPower Electric Bike Battery 20AH 36v 48v 60v 72v LiFe...
and then I saw someone else post this motor:
Is this an ok plan - what else would I need to complete the build or would you go with something else entirely?
thanks
rob
Maximus
Wow that is clean, an definitely way faster than the stock set up. What battery did you use and what do you use for a throttle control, didn’t see a pedal on there
Thanks! :thumbsup:
Damien is powered by (4) 12V 12AH SLA (sealed lead acid) batteries (SLA's don't need a BMS)
...& has hand controls (thumb throttle & brake lever)
She also, has "incognito" rear suspension
...a (3) speed feature (low, med & high)
...reverse
...& brake lights too:sifone:
* Read thru the thread (click on link in my last post) it covers/shows all of these features :cool:
Many "factory made" lithium batteries for E-bikes (what many folks use for small go karts) have the BMS built in
...just gotta double check the "specs" to make sure it satisfies the requirements of your specific system/set up ;)
It's usually the DIY'ers that build their own battery packs (not recommended)
...that need to add BMS protection :cheers2:
