So now we got an idea of your curent experience
you mix 15 fuels per oil by volume
(no matter what unit, liters, quarts, gallons, cups, tablespoons as you like and need.. 15 fuel one oil)
you should NOT mix oils IMHO, but you can if you like..
what ratio to mix the oil at is up to you; again I wouldn't.
pick one, then the other, see what your engine likes better, then stick with that.
if PO doesn#t say he mixed oils in certain amounts, then he unlikely did.
(he just used different oils for different tracks most likely)
engine rebuild in race engines is done every now and then,
it's part of the "usual maintenance"
it's usually honing the cylinder walls (remove wear),
refitting either oversized piston rings OR oversize piston (depending on wear and age of the cylinder - eventually replacing the cylinder piston combo),
replacing the bearings against fresh ones (done every time),
Assuring good sealing surfaces (head, deck, case halves, ports)
and where necessary replacing the crankshaft.
Blueprinting is essentially a marketing gag most of the time!
They rip you off and do nothing most of the time.
TRUE blueprinting is an INSANE amount of work, and pretty useless on a single cylinder engine.
What it would be on a single cylinder engine is bringing the engine back to ideal stock.
(new cylinder and piston, new crankshaft, crankcase replaced when worn..)
THAT is exactly what a rebuild does when due!
At best it'd be matching a few conrods/pistons against a few crankshaft to see what set runs truest in fresh casing halves, but new race parts have such tight tolerances that it essentially is
pointless.
On a multi cylinder engine it matches piston/conrod weights against each other balancing the
ghost out of every moving part normally requiring 4 to 6 spare sets of engine internals to get one perfectly blueprinted one, sometimes more.
IIRC Suzuki used 25 RF900 engines to make the record breaking one back in the nineties...
Anywho, it's BULLDUNG on a single cylinder (marketing gag to rip you off)
and likely unaffordable on a multicylinder for us Homegamers.
(you bought a used kart since it was cheaper, right? since you obviously are not thinking it looks better
So, what do you want to spend? 650 for a rebuild or 3800++ for a true blueprint?)
