dengieboy
motor
Go careful running a two stroke that has been sat for a long time with out running. Two stroke rely on pressure the fuel/oil mix is drawn round the crankshaft here it lubes all the moving parts there will be two crankshaft seals on either side of the crankshaft these seal the crankcase from the outside air. Over time these seals will go hard if the motor is not used if you then go to start and run that motor it will run but the seals will not last long. And as they wear they let air in which then throws the fuel/oil air mix out which could lunch a piston if not noticed Another thing that will not help is if the motor had done a lot of hours (the seals do wear). Another thing to give some thought is that a two stroke has to be run on the correct mix of fuel and oil if this is not kept to you can trash it in seconds so do you know the history i would guess the answer is no so do you want to gamble that the motor is worn?. I would say if that was mine i would strip the motor down put a new set of crank seals in check the crank and big end bearing while i was there. I would then give the top end a check the small end bearings on two strokes can wear (again with lack of two stroke oil) they do suffer with carbon build up if cheap oil has been used this can happen behind the piston rings. Carbon build up on the cylinder head can cause hot spots which can pre ignite the mixture again which can lunch pistons.
I have worked on many many two stroke motorcycles any question you may have send me a message i will say nothing beats a two stroke i owned a 350 yamaha powervalve LC and the power band was like warp speed many many tricks can be used to get more out with out it going Bang!!!!........ Please don't kill it by not looking
