r6 powered monster kart build
yamakart
Hey guys, After browsing the forums a bit I think this would be the correct place for me to ask a few questions on the build im currently working on.
I'm finished building the frame for now ( a 28/28 go kart frame extended 4 ft in the middle and made more rigid using good welding technique and allot more metal.) and im looking at building the motor mounts. Before I mont the motor I want to get the sprocket and chain lined up and set on the right angle so i can see if anything interferes. or if im going to need to do some more serious modification.
My question is: If the motor uses a D.I.D. 520v chain (brand new) Is there a sprocket that will mount the go kart axle and give me a decent (somewhat useable, i know its stupid power.) #of teeth that will work with this chain.
Or am I going to have to build a pulley system above the axle and go from motor to bike sprocket than convert to gokart sprocket and down to the axle with a go kart sized chain and another "normal" sprocket on the axle.
I have some pics of the build ill work on posting tonight. However any help is appreciated. and ill try to give as much info as i can.
yamakart
I may end up answering my own question... but i found these
http://gokartsusa.com/gokartminibikesprockets-2.aspx
5.25 bolt circle on the sprockets them selves .. same number of hols as my sprocket mount on the gold kart frame... the holes on my hub are about 5.25 from one side to the opposite. but still how many teeth? and should i change the front (motor side / drive) sprocket and if so how many teeth? I there a ratio calculator that takes into account tire size?
anderkart
Surprise Arizona USA
I'll help ya figure this out but I need more info:
What year is your R6? (We have to look up your transmission and primary reduction ratios)
How many teeth does your counter sprocket have now?
What diameter is your axle?
Are you using 11" tall back tires?
And how fast you wanna go?
yamakart
hey man, thanks for responding.
i believe the motors out of an '06 yamaha r6.
axle dia. is 1.50 in
back tires are like 7" or 8" overall, ground to top of rubber.
like i said with the gearing im looking to slightly tame this beast. im pritty sure it will go fast anyway. but streight and fast is nice.
if its got so much power it wont stay streight ill end up re gearing. im sure you kinda know what im thinking. like that r1 thats on youtube. lol
ill help clairify these rough numbers tomorrow with exact measurements. thanks again for the help. sooner i get the right sprocket sooner i can mount the motor properly.
