Hey guys, After browsing the forums a bit I think this would be the correct place for me to ask a few questions on the build im currently working on.
I'm finished building the frame for now ( a 28/28 go kart frame extended 4 ft in the middle and made more rigid using good welding technique and allot more metal.) and im looking at building the motor mounts. Before I mont the motor I want to get the sprocket and chain lined up and set on the right angle so i can see if anything interferes. or if im going to need to do some more serious modification.
My question is: If the motor uses a D.I.D. 520v chain (brand new) Is there a sprocket that will mount the go kart axle and give me a decent (somewhat useable, i know its stupid power.) #of teeth that will work with this chain.
Or am I going to have to build a pulley system above the axle and go from motor to bike sprocket than convert to gokart sprocket and down to the axle with a go kart sized chain and another "normal" sprocket on the axle.
I have some pics of the build ill work on posting tonight. However any help is appreciated. and ill try to give as much info as i can.
