what should I look for when I pull the flywheel off a gx31 Honda and a donor clone gx2? are they keyed, is there a timing mark, is it just the 14mm nut?
should I start a build thread here?
pilsner or ipa?
should be a woodruff key on tapered shaft, but you'll have to make sure the magnet is on same position of flywheel vs. keyway location before completing the swap
thanks mckutzy, hope you find your clutch oddball, this place is motivating me to get this kart going.
I got the flywheels off and switched and now need to know the secret to removing clutch shoes or is it just more force?
I started this: http://www.diygokarts.com/vb/showthread.php?p=347862#post347862
