Kind of off topic, but i ordered the Azusa kit as stated earlier. I need to order a clutch. Would this one work?
http://www.bmikarts.com/item/Hilliard-Extreme-Duty-3-4-Clutch-12T-35-404600-6514
Thanks.
That would be correct. I'll keep an eye out on an engine for the 3/4" shaft. Thanks.if using an engine below 13hp with a keyed 3/4" shaft. yes
the kit should come standard with a #35 chain and 72t sprocket, a 12t clutch would be 6:1 ratio, if you want a different ratio you may consider a different clutch. (6:1 is a good ratio anyway)
