Questions for someone electrically inclined
I understand your confusion. I read the entire article, and although it refers to "grounds" many times along the way, it never explains the distinction between ground and neutral. It also leaves you ASSUMING that two wires come from your panel to the outlet- one hot, one ground- and therefore makes no explanation for the third prong of the outlet.
dave1701
Good for 100,000 Miles
MICHIGAN
Source #2-
Wikipedia
Definitions
Ground or earth in a mains (AC power) electrical wiring system is a conductor that provides a low impedance path to the earth to prevent hazardous voltages from appearing on equipment (the terms "ground" (North American practice) and "earth" (most other English-speaking countries) are used synonymously here). Normally a grounding conductor does not carry current.
Neutral is a circuit conductor (that carries current in normal operation), which is connected to earth (or ground) generally at the service panel with the main disconnecting switch or breaker.
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
Neutral wires are usually connected together at a neutral bus within panelboards or switchboards, and are "bonded" to earth ground at either the electrical service entrance, or at transformers within the system.
It seems as though the earth does serve as the neutral, but the location of the tie-in point varies.
dave1701
MICHIGAN
At the point of service where the utility's supply neutral meets the customers meter....the neutral is bonded to ground...usually by a rod. This establishes a solid ground path both for the customer AND the utility. Once the service is tapped and energized - this bond...as you know...must not be broken..it is essentially for the proper flow of electricity.
What does this mean?
dave1701
MICHIGAN
So if you got a light bulb and had one end plugged into a hot AC wire from an outlet, and had the other end buried into the earth (ground water), would the light bulb turn on?
CaptCanadia
Acton, CA USA
So if your in bare feet and touch a hot wire it's going to possibly kill but if you're wearing say work boots with a thick rubber sole it will just tingle your hand?
dave1701
MICHIGAN
Edit/Delete Message
devino246
Lynchburg, VA
Edit/Delete Message
Depending on how good its grounded.
