Questions about this performance kit
Bobby24
Oklahoma city
So I bought this kit for my predator 212cc engine ihave a couple questions.
http://www.ombwarehouse.com/Predator-212cc-Go-Kart-Kit-Stage-1-Non-Hemi.html
First off do I need the stronger valve springs when i dont have the governer removed or anything else done internally?
2nd how do I install the advance timing key, is there a link to instructions if the kit doesn't come with any? And will i need the valve springs after its installed?
Info or tips on anything in this kit from anyone are appreciated.:auto:
Bobby24
Oklahoma city
Ok thanks, what about the jets and imulsion tube? I dont need the advancekey for it?
If not I'll save them for if I do some more advanced upgrades later on.
Poboy kartman
Senior Moments Member
White Settlement Texas
Ok....jets and emulsion tube....YES!!!!
If you upgrade to a better breathing exhaust....(i.e...move air through through the engine) ....you must move more few as well....
Advance key....maybe...try it and see....
Stronger springs....NO NO NO!!!! You don't need them until you remove the governor ...AND DEFINITELY don't want them before adding a billet connecting rod aftet removing the governor....(removing the governor and using stock springs is ok.)
tazmannusa
Yettem, California
Yes you will need the jet and emulsion tube when you install the air filter and pipe other wise it will run to lean. Save the key and springs for latter if you remove the Gov and add billet rod
Bobby24
Oklahoma city
I installed the intake and exhaust and a breather on the pressure relieve hose. What do i do with the hose coming off the top of the fuel tank?
You can add a small fuel filter if you want, I just removed the hose. It has a check valve in the L fitting.
Zombient
Junkyard Derelict
Waco, Texas
I love digging though my old threads.
YES!!!-- For what seems like the thousandth time....if you remove the governor....DO NOT UPGRADE THE SPRINGS!!!! ~without replacing the connecting rod with a billet one first!!!!
There was just recently a thread where a guy blew a billet con rod.....no way it's a good idea to use stock.....
And people think....well....I'm not gonna run it wide open all the time.....NO..... the forces are there...and while the more you run high rpms, the greater the chance of failure, the truth is, if there's a flaw in the stock rod that's exceeded by pressure....it doesn't matter if it's just a split second.....
And this is the thread he was talking about.
http://www.diygokarts.com/vb/showthread.php?t=30917
