Questions about Briggs V twin engines
Bigredford
Hey guys I pulled a good running Briggs V twin engine off of a Generac Generator its a 303775 vertical shaft I beleive its a 16 HP model. I plan to put it on a vintage white lawnmower to make it go faster. Cause I been watching to much Lawn mower racing on youtube!:lolgoku: I know that there seems to be two different models of these Briggs V twins with some head differences. What I'm wanting to know is what Crankshafts will interchange with this engine. This one has a special crankshaft PTO end is short and tapers drastically. And that end had a "flywheel" with a 4 rib belt that connected it to the generator. This flywheel is pretty much a copy of the upper flywheel its cast iron only its a bit lighter and has no magnet. Complete with cooling fins had the same setup on the generator end only smaller/lighter and smaller cooling fins. It was set up to run off of propane so I'll need to get a carb too and some better looking tins. the tins on this thing are fugly! So any info on interchange would be greatly appreciated! I'll try to dig up some pics of it its got a pretty unique set of tins...
Bigredford
Here are some pics of an identical Generac, I've already pulled my engine off. Wish the generator part of it still worked didn't realize how expensive thoes things are!
