Questions about Briggs 5hp flathead.
Bigredford
Hey guys. New to the forum and had some questions about a Briggs 5hp I recently picked up for cheap for the go-kart I just picked up for cheap
It came with no tins so I'm not really sure its a 5hp, might be a 3.5 Its identical to a 5HP funtime briggs I have thats got a busted block on another kart I have Is there any other way to tell what this thing is without the tins? So if I have to rebuild I know what to buy.
I don't have the engine running yet guy I got it off of said he had timing issues with the camshaft. Took the back cover off and lined up the dots on the crank and Cam and replaced a sheared Crank key. I have had to spin it by hand because the tins from the funtime engine are missing the pull starter. I am in the process of getting a new one. It spins way too easily and seems to have no compression and its "burping" through the carb. You can put your hand over the carb and feel it blowing air pretty easy. Suspect that the valve might be leaking around the seat or possibly be bent but haven't done a leakdown test yet. Something has been bouncing around as there is some damage to the top of the piston and to the head itself but it didn't seem to damage the valves any. I tried swapping the head with the one off the funtime engine but still same issue. Anyone have any ideas about the burping through the carb? Thanks in advance guys!
Someone else's hands have been it and it has a sheared key and he said realign cam?
It too easy to tear it down and inspect everything. I would.
Sounds like a bent valve.
Bigredford
The guy I got it from said he had been in it and thought he had the cam timed wrong. I opened it up and it was off about three teeth. So I lined it back up again. Pulled the flywheel off and found that the key had been Sheared so I replaced key. I think he was messing with the cam not knowing that the key had sheared. I only paid $20 for the engine mostly for the block but thought it would be good if I could get it running and not change everything over. If everything from the Funtime 5hp fits it is it a safe bet its a 5 horse?
KartFab
Dallas, TX
take the valve cover off and see what is stamped on the inside the rear of the chamber that houses the valves iirc some 5 hp ones have a "13" stamped back there for yoru cubic inches of displacement, which would be ~213cc
also they have the same bore, just different stroke. so if you measure the stroke somehow (by pulling the head) and knew what the stroke was between the two, then you could get it that way, even with a dinky ruler or tape measure.
5 hp stroke 2.438
3.5 hp stroke 1.750
also the 3 hp has the same stroke as the 3.5, just a smaller bore.
hope that helps.
have you checked valve lash?
Bigredford
Nope have not checked the lash yet, and thanks for the info. I'm about done fiddling with it today and will mess with it on my next day off...still have to look up the lash tolerance unless someone wants me to save the time. I also noticed that in the old oil there was quite a bit of aluminum material and and when I pulled the cam out there was some decent sized aluminum flakes on it. I have a feeling I need to go ahead and pull the piston out and check the piston and bore. But that will be for another day.
FYI- Adjusting the valves is not as easy as the clones.. Usually needs to grind material off of the stem...
Staff Murderator
Bigredford
Ah if the bore is the same then thats an easy fix for me. I was planning on beefing up the internals with a billet rod and heavier springs/hotter cam anyway for the go-kart anyway. Would a bench grinder be too much for grinding the stems? Also thanks for the info guys.
I think that's fine, as the last YT vid I saw buddy was using just that...
You'll have to look that up..
Bigredford
Whelp did a leak down test and found my issue, bent intake valve and lots of valve guide wear, pulled the valve out and one side of the valve where it meets the valve seat was worn smooth out and the other side was almost new looking, valve was leaning enough that it didn't even seat on one side. As a matter of fact you could move the valve back and forth with it fully seated in the valve seat with a finger! Gona have to grind the valve seat most likely to get it straight again and definately gona need to put new guides in. Question is would it be cheaper to buy another block? I have a drill press but if I got to put a new valve seat in that might be a problem. Any suggestions? And I don't know of anyone that does machine work on Small engines in my area...heck if I could find a decent Machine shop at all where I'm at I'd be happy!
Staff Murderator
I have several auto engine machine shops in my A.O. and they are primarily for hot rods and such. You wouldn't know they'd do small engines by looking at them, but they do.
I brought my valves in to be refaced just like in that video and after he was done, he was all set to re-do my valve seats, lap them in and so forth, only I didn't bring the block with me. :eek:
If you learned to install new valve seats and guides on your own, that would open up a whole new world of refurbishment possibilities. I've run across quite a few with decent bores but worn out valves.
Flat head engines are very hard on the valves and that's where most of the failures (lost compression) occur.
Bigredford
Yea the problem I have is that there are very few auto engine machine shops around my area...I think the closest is about 2 hours away and they are always super swamped. There was one closer but he retired. I have done head work myself at home as a matter of fact I just did a valve job on my old 7.3 Diesel about a month ago, spent all my "car money" on it main reason I'm messing with all these lawn mowers my dad has collected over the years so that I'd have something to do on my days off. At least until I build my hotrod money up again. I think I'll buy a new set of valves and test em in the engine before I decide if I need new valve guides. Also It seems I have a knack for collecting Engines I have no clue what they are. Just picked up a Generac Gen set out of an old motor home that runs real good. No markings on the engine tins cause Generac used there own tins but I'm suspecting its a Briggs V twin engine. That would look real good on my hot rod riding mower.....
