tombarr247
Hey guys,
I have been pondering over what to do with my live axle setup for quite a while, and decided to ask for your help..
Basically, I am building a kart intended for off-road use.
I currently have a 30mm axle and axle bearings, brake disk and sprocket to suit the 30mm axle from an old kart.
I also have broken an old ride-on lawnmower, so I have wheels to suit a 3/4" axle.
My conundrum is this: I want to minimise cost (doesn't everyone!) by using as much stuff that I already have, because in Ireland.... parts don't come readily available or cheap, as karting is not big here AT ALL!!
Would the axle be too weak if I were to turn down the ends of the 30mm axle to 3/4", then thread the ends of the shaft and bolt on the keyed wheels? (The tyres are 19" diameter.)
I have considered getting rally hubs to suit my 30mm axle and then dril holes in the old lawnmover rims to suit, but the problem is the rims dome outward in the centre (are not flat) and could prove difficult to mount to hubs...
If anyone has any ideas/help/info it would be much appreciated!
Thank you kindly in advance
Keep up the good work!!!!!!
