Touchngo
I have a question on rear wheel size/weight and was hoping someone here could help me out. I am currently building a cooler racer (similar to a bar stool racer). It has a HF 6.5 HP engine with a larger emulsion tube, jet, and air cleaner. Plan to add an exhaust pipe as well. I am using a TAV 30 on it as well with a 12 tooth sprocket. Axle sprocket is 73 teeth. Solid 1" hardened steel rear live axle. #35 gold chain. I have a 10 tooth sprocket I can put on the TAV as well.
I expect the frame to weigh in at about 50 pounds. Add another 50 for the motor, and another 300 pounds worth of cooler, beverages, and rider for a total running weight of about 450-500 pounds (once the weight of the wheels/tires is also added in)
So, I was planning on using 6" wheels with 145/70-6 knobby tires for all four wheels. I know most bar-stool racer use go-kart slicks, but I'm building a more "off-road" one. That is plan "A" for the wheels / tires.
I also am interested in the following for the rear: 18 x 9.50-8 knobby tires, while keeping the fronts at 145/70-6. This is plan "B" Supposedly these tires weigh in at about 20 pounds each, not including the rim.
Having no experience with building a go kart before, I just don't know if the engine will be able to turn the larger wheels and generate enough torque to get the whole thing moving.
I am more interested in torque than top speed, and know the smaller wheels would offer more torque, but if the larger wheels would work, I would prefer those. As long as it could go about 20-25 MPH that's all I care about for top speed.
Any advice would be greatly appreciated. Thanks!
