question on kill switch wiring tecumseh OHH60
nsurdis
Hi all.. new to karting.. but i consider myself pretty handy with full size engines lol.. just got the kids a Carter kart with Tecumseh OHH60 motor.
Runs and rides real good.. only problem we are having is neither of the two kill switches seem to shut off the motor :)
I've done some research and it seems pretty simple - kill switch in shroud and on steering wheel both have a ground side, then tie into a green wire which goes to the kill lead on the coil.
All wiring seems good, except when i hit the switches, it doesn't kill the motor. The strange thing is the green wire which supposedly goes to the coil to kill it, actually goes to a screw terminal on the bottom back of the shroud. (picture attached).. is this the right place? It doesn't seem like grounding out this wire/terminal is killing the motor.. any ideas? Thanks all!
https://www.dropbox.com/s/xm9smt06h4qb5up/File%20Dec%2026%2C%209%2029%2037%20PM.jpeg?dl=0
supermanotorious
Winchmaster 5000
New River, AZ
need to find a wire that comes out from under the shroud, if that green were the kill ground, you'd never be able to get spark as it is always grounded
nsurdis
theres a red switch right on the shroud near the air filter assembly which this green wire comes out of to the ground.. the other end of the switch has a black wire.. can't see really where it goes.. i would guess to the coil.. the switch doesn't seem to do anything/kill the engine when flipped... i tested the switch .. tests out fine..
Poboy kartman
Senior Moments Member
White Settlement Texas
Ok...the green wire coming out of the shroud IS the kill switch wire. It goes to an isolated (plastic ) spot on the shroud exterior. It's sole purpose is indeed to provide an easily accessible ground to the coil.
Connecting this wire to ground should kill the engine. While not out of the realm of possibility, I find it hard to believe this doesn't work.
nsurdis
Got it - thats what I thought - so if I ground out that isolated terminal it should kill the kart right?
I know its pretty easy just to go test it rather than ask this question, but I've been working a long stretch and havent had a chance to fire up the kart and test it... ;)
Weeder
It's 4:02 Somewhere!
Boulder, Co
Dude sometimes my cart doesn't stop either. Sometimes its the kill switch and other times its the brakes but if I'm really stoned and it wont stop I just run into a tree or something.
Party on! :cheers2:
