question about torque converters
devilstear
cali
im kinda new to this an i was wondering if anybody knew if just any jackshaft would work with the driven so as long as their aligned to the driver, or does it have to be the ones they have made for it,any info will greatly be appreciated.this is a 40 series tc by the way and does the diameter of the driven have a matter like 7 or 8in i hope this is the right place to post this question thanks..
ANY jackshaft will do- mine is homemade... 3/4" keyed shafting (generic) cut to size, Two standard pillow block bearings, output sprocket of your choice, misc hardware as needed.
You need to give yourself a good idea where you're going to mount it, measure the approximate center distance between your J/S and crankshaft, and reference that measurement on the Comet chart. When you have found the closest number on the chart, mount your J/S EXACTLY at that distance- it's critical.
devilstear
cali
thank you much i was thinking any should work the same way but had to make sure as sometimes thing are never like what they seem and for something like this i needed to know 100% but yeah i will do so thanks again
