Question about pulse fuel pump.
BPT7594
Hi,
I'm new to the forum.
I got a pretty strange project on my hand.
It's not exactly a go kart. But the idea behind using a pulse fuel pump (which is pretty popular I think) is essentially the same.
I have an engine with the misfortune of having the fuel tank on a lower level than the carburetor.
I fitted the fuel pump in the attachments (it's meant for a 150cc scooter), that's the only pulse pump I can get.
1/ The inlet line into the pump is fitted with a standard fuel filter (not screen).
2/ The outlet line into the carburetor is also fitted with the same type of fuel filter.
3/ The pulse line is connected to a fitting I drilled and installed on the intake manifold, image is in the attachments.
Question:
1/ If I understand correctly, the pulse fuel pump, if connected to the intake manifold, would work based on the rpm of the engine?
2/ With my setup, will my intake valve's health affect how the fuel pump works as well? Since the vacuum is created through the intake valve after all?
3/ Now the strange part, I tested my pump today. At idle (about 1600rpm), the pump works fine. But when I increase the rpm with the throttle, the fuel flow stops.
I did hold the fuel line a bit too high but is this a sign of trouble?
To make sure, I connected everything again, then I take the engine out on a run at a constant 80kph (about 50mph) for 30s. I figure if the pump does not work properly, my engine would run out of fuel very fast at that speed but everything seems to be fine. Any explanation?
http://www.corvetteforum.com/forums...d-venturi-and-ported-new-article-by-lars.htmlThe most commonly recognized vacuum source in an engine is “manifold vacuum.” Manifold vacuum is created in the intake manifold of an engine due to the pistons’ intake downstroke on one end, and the restriction created by the partially open carburetor throttle plates on the other end. If the throttle plates are closed tightly and the pistons are moving quickly, a very high vacuum is created. If the throttle plates are opened more, creating a larger “leak path,” less vacuum is created. If the pistons are moving slowly and the throttle plates are wide open, the pressure in the manifold will be very close to atmospheric pressure – no intake vacuum. Thus, intake vacuum can be used as a signal source to determine how hard an engine is working.
BPT7594
So if I understand correctly, as soon as the throttle valve opens, manifold vacuum which operates the pulse pump goes out the window? Isn't that kinda opposite to the idea of using a fuel pump in the 1st place? To make sure that we get enough fuel flow at high rpm?
I'm using pretty thick tubing though. The tube comes stock with the fuel pump, it's an OEM part from SYM.
Anybody has any idea to ensure fuel flow at high rpm?
I read more fast, less careful LOL. What engine is it on now? What Carb?
Some people use the crankcase or valve cover to pulse the pump.
Make sure the tank is vented (open the cap) and the hoses are tight.
WAIT??? So what is the issue? Since everything appears fine?
Are you asking why the pump still works at Wide Open Throttle?
IDK here is some info related, but I'm just guessing at this point. LOL
http://scootdawg.proboards.com/thread/28235/mikuni-fuel-pump
BPT7594
Well there are 2 things that raised my concern.
1/ since I mounted the pump on the frame of the scooter (a gy6 copy), the pulse line is pretty long. I think longer than 20 inches. But I used thick and tight tubes. Can too long pulse lines make the pump weaker in some ways?
2/ I got curious when I tested the pump. At idle, fuel flows fine. But as soon as I open the throttle, fuel stopped flowing. But somehow when I take it out for a ride it does not seem to stall.. that's really strange for me.
3/ yes if you can explain to me why the pump can work at WOT? Since the article on the corvette page (great article though) mentioned that at WOT there's almost no manifold vacuum which if I understand correctly is what a pulse pump relies on to work properly?
I built this engine as a race/commute scooter for my son who does a lot of commuting as high speed. I don't want him to stall from fuel starving so I'm kinda paranoid about making sure the fuel pump works fine.
I sometimes get confused about crank pressure and manifold pressure and Positive crankcase ventilation,.....
This is murky, unclear water to me. I didn't get my pump to work right.
I will shut up now and let's see if others can learn us something,???
Joe-405
Enjoying New Projects
U.S.A.
you are seriously over thinking this whole pulse pump thing.
i have put those pumps on a 100+hp banshee before and not a single issue out of them. All you need to do is keep the flow moving doesnt require alot of pressure to make them work. if you get too much pressure you will be buying a expensive carburetor so you dont blow past the needle and seat anyways.
BPT7594
I do overthink this, you're right. It's just that the last pulse pump I fitted (a knock-off I guess) for my son got him stranded in the middle of nowhere so I want to make this right.
I do have fuel dripping out of the overflow tube sometimes.
Did you use the pulse form the intake manifold too or the crank case?
Needle valve and needle valve seats need to be size correctly. Some sizes are for gravity. Some are for pumps. Using a gravity needle / seat combo sized for gravity, when with a pump needs a T fitting and a return line to the tank. It lowers the pressure from the pump. Some carbs let you change out the valve/seat, some don't.
This is at least true for some carbs.
Sorry This is just regurgitation.
Thank you DD for this info.:cheers2:
Joe-405
U.S.A.
I always use the plastic round ones. I have never used the squared off ones.
But I always go between the carburetor and intake boot.
BPT7594
Thanks.
My son's engine is a 4 stroke with a breather (crankcase venting) fitted into the valve cover so I guess the intake manifold is the only place I can tap a pulse then. I've read something about Walbro pumps having a spring to push the diaphragm back to help on a 4 stroke. I'm using a Mikuni square one though. Thank you very much.
Joe-405
U.S.A.
My barstool racer has the plastic round one. And it's tapped in the valve cover on the little angled piece with a brass fitting. Sorry i forgot til just now. And no issues with it since I built a few years ago. It's in the buildoff threads. It's a box stock project bsp yellow clone engine.
