Question about new torque converter
bisctboy
Hi,
This is my first post..
My son has a go kart and wanted a new engine for Christmas so that is exactly what he is getting. I am increasing the HP which means it will have a 1" shaft instead of the 3/4" shaft he has now. Because of this, he is also getting a new torque converter for Christmas. I was looking at the Torque-A-Verter or the GTC torque converter. My issue is that the existing torque converter (Comet) doesn't have a mounting bracket while the my 2 options above do. This mounting bracket bracket appears make the driven and driver alot closer together than my existing Comet. If this is the case, the driven will not mate up to the existing jackshaft, right?
How does all this mate up if I get a new torque converter?
I have attached 2 pictures of the existing set up we have now for reference and 1 picture of a GTC torque converter.
Thanks,
mr.matt
Houston, Tx
The Gtc unit is a jackshaft and torque converter all in one (torque-a-verter or tav) . The picture doesn't show but on the backside of the assembly is a sprocket, I believe you can choose chain pitch an tooth count upon purchase. The only problem I see is possibly lining up the sprocket on the axle with the sprocket on the tav assembly. So expect some more modification to get this to work, but possibly just relocating the sprocket on the axle and adjust the chain length too for the correct tension.
bisctboy
Thank you sir...Do you have an opinion on which torque converter is better...GTC or the Torque-a-Verter brand?
Just so I understand you correctly, these units will work with the setup I have in the picture? I realize I may have to do a bit of fabrication to make it work. Also, you said on the backside of the assembly is a sprocket. This sprocket has a chain that connects to the axle somehow?
Thanks,
Your existing unit is either a Comet 30 or maybe a maxtorque. As you have determined, they are stand-alone units. The Comet TAV2 and the GTC are self-contained. Basically, it comes down to two possibilities. You can order the TAV2 or GTC and bolt it on, altering your chain length and sprocket location to suit. Or, you can see if there's a Comet 30 driver with a 1" bore available to be purchased, and swap it and go. I'm not sure of availability, but it might be worth looking into.
to answer your last question- On the GTC and TAV2 units, the drive sprocket is hidden from view right behind the driven unit. They are available in #35 and #40 cahin, so you'll have to see which chain yours uses. #35 chain measures 3/8" from pin to pin, #40 measures 1/2".
Regarding brands- Comet is the real-deal. An American company, known and respected for such things. GTC is a chinese-produced knockoff. Be so advised. I guess some folks have had good luck with it, but Comet is superior.
bisctboy
Thanks for your reply...
It sounds like I am going to have to move the big sprocket on the axle to the other side of the engine so it is on the same side of the engine as the crankshaft, right? I've attached a picture of the sprocket on the axle I think I am going to have to move. Please verify this is correct.
I have to assume that moving this is fairly straight forward and that there will be enough clearance between the mounting plate of the TAV2 and the side of the engine for my chain to go down to the axle sprocket?
Thanks for your opinion on GTC vs TAV2. The TAV2 is actually less expensive by about $30. I did find a 1" replacement for the Comet but it says it's good only up to 8HP and the engine I am putting in is 13HP, so no good there. Anyway, the current set up I have chews up belts at an alarming rate so it's probably good I change it out.
Sorry for all the questions...I just don't want to spend over $500 in an engine and TAV2 only to find out I can't do it.
Thanks,
Woah- Stop!
I did not realize you were talking 13hp, and I was tunnel-visioning on the existing options... With 13hp, you need to be using a Comet 40!!! And, no- I don't care what the GTC literature says...
The 40 will cost more, and it WILL survive whatever you throw at it. Like your existing unit, it is a standalone and does NOT use a mounting plate. There's a very good chance you can re-use your existing jackshaft with it...
bisctboy
OK...Looks like it will be getting Comet 40. Do I need to get a new Driven as well? I have taken a couple pictures of the existing Driven and attached them. It is a Max Torque brand that is 7" diameter. I took a picture of the width as well and it looks to be approx 1 5/16" wide. The belt looks to be 3/4" wide. Knowing this info, can I use it or do I need to get a new Driven as well?
On a different topic, what are the 4 holes on the side of the Driven? I'm sure they are some sort of setting...it currently is set to #2.
Again, thanks for your help!
Thanks,
You will need a new driven. The belt width is one thing, but the profile is even more important. The Comet 40 is symmetrical, using 3/4" belts that have the same angle on both sides. The 30/TAV2 and I believe the Maxtorque are asymmetrical, requiring belts that have a sharp angle on one side of the belt, while the other side is very nearly square. Hard to tell with the pics, but you may have the wrong belt right now.
I need you to have a close look at the driven (or drive- doesn't matter). Do the two faces of the pulley sheave have matching angles, or is one side angled and the other very nearly vertical?
bisctboy
The sheaves have matching angles. I have attached a picture for reference. I bit the bullet today and ordered the complete Comet 40 package. Santa even claims it will be here by Christmas! You said it needs a 3/4" belt but the specs on the Comet 40 say 7/8" belt. I went ahead and bought a 7/8" belt???
What do the 4 settings on the side of Driven do/mean? There are 4 holes and it is currently set to #2 setting.
Again, thanks for all the replies!
Thanks,
Thanks,
Those 4 setting have to do with the RPM's that the clutch engages at. Read the following document regarding comet 40's. It will help you out a lot
http://www.bmikarts.com/PDF/Comet_40series.pdf
bisctboy
Yes, it is a Carter...at least that's what written on the seat. I had a feeling that a 13HP engine might be a lot for it, but my son (14 yrs old) and I now have a good winter project to fabricate the mount, hook up the electronic starter, add lights, etc...wish me luck!
spyder1968
New Bedford, MA
am i missing something here ? why wouldn't you just get a 40 series driver to fit your 1" engine and a driven that matches your current jackshaft size ? then after modifying your engine mount to fit the wider engine mounting pattern, just measure what size belt you will need?
bisctboy
Basically, this is what I did. I purchased a Comet 40 Driver/Driven combo from Northern Tool. The Driven has a 5/8" bore which is what my jackshaft is. I also bought the larger 8 3/16" belt in hopes that I can modify the engine mount in such a way that there will be a little back and forth play to it. If not, I wasted $40 on a belt. I think I'll be able to accomplish it though.
