Quantum 7150 150cc need help
inspiron_it
Quantum 7150
Illinois
OK so I picked up a quantum 7150 that had been setting for a while with bad trans gears which I fixed. having carb issues... the carb will not idle unless I put my hand in front of the carb and barely cover it, it then runs fine. I've went threw the carb many times and cant seem to find the issue, I've replaced the fuel lines, fuel filter, some times it will start and idle then die. I've cleaned the jets, turned the air screw out 2.5 turns as specified in the manual, what am I missing? please help!!
is there something in the carb I have missed?
