Put rim without bearing
Zaza
Is it possible to put a rim on screw without bearing?
Zaza
if you want to bolt it to a wall ... of course!
I can’t find correct diameter for the bearing and screw
Because that I want to know if i can put the rim without bearing and using
jmaack
sure you can then you will be hunting alot more replacement parts than a bearing
J.S.@SMS
Road Hazard
Weeki Wachee Fl.
Why do I get the feeling that the rim is off a lawnmower. Those run bushings instead of bearings. And that's fine at 5mph, but when you get into the mid teens or twenties they won't last long, if they even last at all.
If you run it like that it will potentially weld itself to the bolt... It needs some bushings, and hubs that have a grease nipple..
Smerft85
Southern Colorado
Looks like lawn mower wheels to me, see if the bushings will knock out of the hub, I had to use a flanged bearing to get wheels like that to work, cheap on Amazon.
Smerft85
Southern Colorado
Not sure what size you need, is that a 5/8" axle? You'll also need the inner diameter of the hub itself after the bushings are removed (if it's removable bushings). Do you have a micrometer?
