Pulley clutch and jack shaft
chad551
My sons go-kart has a pulley clutch going to the jack shaft. Then has a 12t chain drive to the wheel. I would like to remove the belt and put on a chain clutch. Has anyone done this, and what size sprockets would I need for the clutch and jack shaft input side? Not looking for more speed, but not liking the slipping of the belt, since the motor was modded. Plus the clutch on there is probably 9 years old, and makes alot of noise.
Thanks,
Chad
chad551
Here are the pics.. I tightend up the belt, but did not get a chance to drive tonight. I do think the clutch is shot as it rattles alot, and they may be the issue.
How is your pulley attached to the jackshaft? If it is just with a key and keyway, then you can easily just replace it with a sprocket. As for the clutch, all you do is buy another clutch which has a sprocket instead of a pulley. You will have to measure the diameters of both the pulleys so that you cann get a sprocket that is he same size.
It should be relatively easy to do the swap.
