easy fix.
here's the problem -- someone put oil, or grease, into the starter pull clutch. ALL THESE PULL STARTERS NEED NO OIL. Buy some carb cleaner, and spray a bunch of that into the little hole on the outside of the pull start thing. (After you remove the outer pull cover)
