Pru's 1st kart
I cleaned up, examined, re-cleaned & re-painted the differential :cheers2:
After the examination, I gave 'er a couple of good wipe downs, with de-greaser
...& then, scuffed 'er up good :thumbsup:
I wiped 'er down again
...then, a final wipe down (ta remove any residue from the last wipe down)
Masked off the axle shafts (ta keep 'em clean & paint free)
The differential has now been Blackened ;)
While the paint was drying, I cleaned up & inspected the bearings (& bearing retainers)
The bearings seals look good, they roll smoothly, no side to side "play" & made in USA :thumbsup:
...& soaked the bolts in a little bit of gasoline :eek:
See that stuff is good for something :stir:
The tubes for the front tires finally arrived
SAM_9000.JPG...& got 'em installed
Cleaned up the seat (front & back)
...scuffed it up
...wiped it down
...& masked off the upholstery
All "freshened" up
The rear rims needed some "love" too :cheers2:
...so, I cleaned, scuffed, wiped & masked them (just around the edge of the rim)
...then, used a handheld "shield" (to save time & tape)
All "freshened" up
Another view
Big difference ;)
While the paint was drying on those accessories, I started assembling stuff on the chassis
Now, with a steering wheel, the twist throttle (& left grip) aren't going to work
So, I got a thumb (actuated) throttle
...but, the plug (& # of wires) are different
An electronic throttle only needs (3) wires
...power (5V+) usually red
...negative (-) usually black
...& a signal wire (it's green on this one but, I've seen many different colors used)
The (4th) wire (blue) on the twist throttle was for the power indicator (which is full pack voltage, of course)
...but, were not going to have a power meter (we'll just insulate it & "leave it be")
Proper plug installed with the wires properly arranged/aligned
...Red to Red (power)
...Black to Black (negative)
...& Green to White (signal)
We can still use the hand brake lever
...it will mount on the left steering wheel "nub"
...& just simply plugs in ;)
Motor & controller are re-mounted
...& re-wired
Chain: inspected, cleaned re-lubed & re-installed
MasterLink
Chain with just a little bit of slack
Adapting a cable pull to a riding lawn mower brake
But, we need to put this thru a little dinky hole
So, I trimmer 'er up
...& then, applied a drop of Super Glue to "glue all of them little strands together
After the glue dried, I pulled the cable thru the housing a bit
...& cut off a little bit
...then, got the brake cable assembly, all assembled ;)
Tie rods all freshened up
I marked which end went to the right side to help simplify re-instillation
SAM_9037.JPGRe-installed
Wow! I just noticed how the sunshine really affects the color rendition on camera (the true-blue color is in my shadow) ;)
I also, got some nice looking bolts for installing the steering wheel (of course they only come in packs of 2) :huh:
Installed
Lock nuts all around
Steering wheel with hand controls
Another view
I got most everything "freshened up" & re-installed
The last thing is a battery cover
Looking thru my plastic "stock" I found an old aquarium cover that may work
A cut-off wheel cut it "like butter"
Here is the piece (center) that I'm thinking, should work :thumbsup:
The cut-off wheel leaves a bit of "build up"
...but, after cooling, that "build up", "snaps" right off (pretty cleanly) ;)
Battery cover cleaned up & installed
SAM_9080.JPGEven installed the Charge Port (with cover) right on top
...so, it's easily accessible :cheers2:
Don't forget the 24V 2A Charger
Charger specs
...& charge port
Had to "get 'er done" :thumbsup:
...we're delivering it up to my little Pru, this 4th of July weekend :cheers2:
Double Bonus:
We're going to spend the weekend (Va-ca) in Mackinaw City Mi. :bannana:
Finished pics :sifone:
Profile
Front
Back
Batteries & Cover
Differential
Hand Controls
Hope she likes it :cornut:
Lookin' good FA! A bonus of E-power is it's nor nearly as frightening for lil ones as gas. Make sure to put some small American flags on it since you're delivering on Independence day.
