prototype buggy
tazmannusa
Yettem, California
Did something not so smart yesterday, took it for a spin flinstones style with string attached for throttle, wanted to check steering and it seemed to work out ok . The swing arm amazed me the way it absorbed the bumps, I think it will work out good , I sure like the smooth ride. No more test rides till floor and brakes are done
Awesome
tazmannusa
Yettem, California
Thanks
Well I got the floor and master cylinder installed but I had forgot to get more brake line so couldn't finish. did some more test runs , changed gearing to 6.25:1, with the 780 series clutch with 30% overdrive it could be a little lower yet . worked on getting the engine dialed in, had to run with the choke partially on and come to find out the jet that came with the stage 1 kit was smaller than the original.
The way I did the steering the outside tire turns a little more then the inside when cranked hard over, was a bit concerned about it but it seems to work good , only option would be to make shorter pitman arms but then the steering would be to stiff. if you think about it when turning hard with a bit of body roll the outside tire is the one doing the work anyway.
tazmannusa
Yettem, California
For the most part it's finished
got it painted couple weeks ago, handles good and a nice smooth ride
tazmannusa
Yettem, California
I would have to build you one so I would need to know what stage of completion you want and for what engine then I could give you price ?
