Proper compression.
Bbqjoe
Banned
Location, Location
I don't know from ratios and what have you. (yet)
I just picked up a gauge to test my original clone before I do port and polish and clean it all up for a re-install.
I came up 125psi.
This is a good thing, yes?
:wai:
Please circle one.
Flyinhillbilly
The great cornholio
North West Arkansas
For sure not a bad thing, but a port and polish won't change your compression unless it lowers it by polishing the combustion chamber. It would probably not be enough to see on the guage though.
Bbqjoe
Banned
Location, Location
No. That wasn't the idea.
I was checking to see if while I had this engine out whether I needed to do anything such as rings or whatnot.
This tells me I'm good then.
NOW I'll open it up and give it a good cleaning and all for it's rebirth.
I was really afraid I might have sucked enough dust in to do some damage.
Sometimes I like it when I'm wrong.
125 psi? That sounds great!
Was this a compression or a leak down test?
Compression test by screwing into the sparkplug hole and rolling the engine over several times?
Or leak down by using 2 gauges and a regulator, giving the cylinder compressed air and reading the difference of what the regulated vs. held pressure.
The latter gives a better indication of ring and valve seal.
Not that the first way is bad but if the ring grooves are full of oil it can give a false high reading.
The way I see it if your over 90 psi your doing good.
Bbqjoe
Banned
Location, Location
I rolled the engine over alright!
I was a bit perplexed as to what to turn the engine over with. I finally decided on an electric (plug in the wall type) hammer drill, set without the hammer.
I pulled the trigger and the engine turned over once, then literally rolled over a couple of times! :D
It flew off the bench, and landed on the concrete floor.
The only thing busted was one of the gas tank mounts.
I decided to finish the test with the engine bolted to the bench.
I just did the compression, not a leak down, but I'm satisfied that this engine is still in good shape.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
That is Classic.:roflol:
Hey next time you decide to try new things Please have a camera rolling!:popcorn:
