Propane
Kenny_McCormic
Kartless....
Michigan Troll
But there is no way sorry can happen.
That is unless there is a hole or something in the tank...but you are correct.
If you have ever gotten into the spudgun hobby, you would know that the explosion from a perfect mix of propane and unpressurized air is less than that of a propane tank on a hot day. Im an insanly cautious guy but your worrying far to much.
risto
...watches you sleep.
Central Florida
the amount of propane with nitrogen+oxygen is between 3-8% in order to cause an explosion. any more and the propane will become 'diluted'. any less and it will be too rich to ignite.
gocartkid
Bad Attitude
CT
My bad, I wasn't thinking about the "perfect ratio". However I still wouldn't want to be around a full tank with a hole in it!
sayre315
Rupp enduro
Oklahoma
well, my mom and dad own a janitorial buisness and they used to use briggs for there scrubbers and they said there not realy good propane engines so now they use hondas and kawasaki
ineed2fly
If you have a section of the tube with holes in it, like on a blowtorch, it should mix gas and air, so no need for a carb, and then if it ever backs up, it will blow out through those holes, like on a blowtorch.
modelengineer
Lord of the noise
Sydney, Australia
To run on propane you need to buy/build a "propane demand valve". When the engine would normally suck fuel, this suction opens the propane valve. As the engine speeds up it takes in more gas. I THING (not sure) that this demand valve, and changing the needle/seat in the carburator for a larger one is all that is required. Along with new fuel pipes.
