Have you though about a crane? Then it would be really useful. I just put one on a utility truck today. Looked pretty BA when we finished.![]()
As a matter of fact, I have. I've got so many really interesting ideas for II that I can't use them all, and have to try to prioritize. I am able to use the other end of the crankshaft (horizontal engine on II) for an auxiliary PTO drive, and I may use it to drive a hydraulic pump. From there, I may use a ram for a lift arm, crane, tow apparatus, etc. I may use the aux PTO to drive an alternator, rigged to an invertor for portable AC power, or maybe an onboard welder.
Of course, I only have one aux PTO shaft, and I only have so much space on board, so I am not yet sure which way it's going to go.
Right you are on both counts. I was a 4WOR subscriber, too- and I bet you're talking about the Premier Power Welder!
I've got a couple aces up my sleeve for the hydro stuff. Do keep in mind this is lawn-tractor based, and therefore "fullsize" parts are waaay overkill.
PatI don't plan on running the pump when not needed. I have the option of an electric PTO clutch formerly used to engage the mower deck blades, or maybe even a simple belt tensioning pulley system.
Have u thought about pto
What do u intend to run withdraw hydraulic
But pto is going to be way Easter to run mowers and post hole diggers and stuff
