PROJECT: (S)crap Kart
r_chez_08
Should be in the shop...
Cornwall, UK
i hate it when people say their projects cost nothing cos they have it all lying around, like just a spare clone there lol! looks great for a kart claiming to be crap!
freakboy
the names 'mater
hick town
dang that sucks man but you should try a faster setting on your milling machine there. might make them look a tad bit better but good job on them things they be shiney!
Kaptain Krunch
Pro Junk Collector
vermont
I wont tell you what engine is just sitting in the snapper then :ninja:
Told you it was gonna be ghetto, I guess i shoulda used a sharp 4 flute, i was using a dull 2 flute, and no coolant :roflol:
Kaptain Krunch
Pro Junk Collector
vermont
Final update of the day, quite a bit of progress, its really coming together.
Kaptain Krunch
Pro Junk Collector
vermont
DONE (basically).
Got the rear end done, throttle linkage, steering, seat, etc. Took it for a test run, ran into a few problems but its still pretty sweet. First the front suspension has no rebound, so once you hit a bump its bottomed out and stays that way, the back is a little better, sags about half way and will rebound back to there after a bump. Second the gear ratio is WAY to high, 6:1 with a crappy tecumseh and 21" tires haha, my clutch got red hot after no more than 4 minutes of cruising full throttle.
Took 5 days from start to finish, cost Less than $10 (bought 4 cuttoff wheels and only used one) so like $2.19.
awesome cable splice job
newrider3
Colorado
Awesome! As for the front suspension issue, you needed to mount the shocks more perpendicular to the ground, and you mounted them further parallel to the ground.
Kaptain Krunch
Pro Junk Collector
vermont
I figured moving them out further on the a-arm would reduce leverage from the tire? I guess i know what i have to do now, kinda dont feel like doing it. I might just scrounge up a couple extra shocks and double up.
Kaptain Krunch
Pro Junk Collector
vermont
Only the greatest creations come from my workshop lol. Another funny story, i made the thing too wide to fit out my door, i had to lift it up and turn it on its side to get it out, and as i did a tire fell off lol.
newrider3
Colorado
The only problem with moving them out further like you did is when the arm cycles, instead of compressing the shock, it just levers it around a bit. With it parallel to the arm it wants to act like an upper a arm, but there aren't enough pivots for that to happen, so it locks.
Kaptain Krunch
Pro Junk Collector
vermont
Yea, i feel kinda dumb now, i wasnt really thinking about it before, now it seems so obvious haha so i guess i gotta re-do the shock mounts, i think i'll figure out my gearing/clutch issues first tho.
