I have my fingers in too many cookie jars. First was a Scout, then along came another Scout, a motorcycle, a spare engine to be used in a home built bike, and now a go kart.
Been on the lookout for a kart, and found this locally. Kinda didn't want it, but my brother seemed to want it so I paid the $100 and we loaded it in the back of my Jeep. It came with what you see, plus a bucket of parts that included one wheel/rim combo, one tire, motor mount plate, seat, and some tubes that the owner had chopped off. In addition he had bought parts to make it a live axle, so I had bearings, bearing plates, and a differential axle. (more than worth the money I paid)
This is what I had upon unloading it.
Cracked frame, both sides are bad.
I'm not sure what he was going for here. The story goes that the "axle" broke so he cut it out to fit a real axle with a differential, and maybe a bigger motor and tires.
My brother and I discussed the fate of this pile and I let him loose with the angle grinder.
End of the day. Kind of a crap picture but there's not a whole lot left.
Harbor Freight happened to have one 6.5 hp motor on the shelf, and unbeknownst to me it was on sale, so I got it and 2lbs of 1/16 welding rod for $125. I was surprised at light the engine is.
So, over the next few days we are going to build a new seat frame, relocate the steering to the center, repair the cracked sections, rebuild the back end, weld on bearing brackets for the rear axle, and weld on the motor mount plate. I'll need to order new wheels for the rear and a clutch and chain.
the rear end will be loose enough to turn on anything.
