sp i decided to build my first kart. I bought a set up that I thought needed very little to get off the ground. ran into a problem today.
I finally got a chain on and started it up, when giving gas, it would not move and the clutch started to smoke a little. I checked on the forums and found a similar problem and the answer was gearing..
I have 18" tires and 54t on the axel sprocket. the clutch has 10t. if I did my math right its a 5.4:1 ratio. Is that bad or do I need to re set it up.
Also I noticed the clutch was on backwards compared to almost all pictures I have researched on the net. PLEASE HELP!
Like to have a new hobbie, But im started to rethink my choices.
