Problem Attaching Throttle to Motor
lycsailor17
I have a 6hp briggs and stratton motor, and I don't know where to attach the throttle to the gas pedal in the car. It came from a pressure washer and has a big throttle you would adjust under the gas tank and the thing on the carburetter that really controlls the speed. They are connected together. Where should I connect the cable? I will post pics later.
lycsailor17
Pics of Throttle
I know I can use the motor, Its tuned up and everything I just need to put it in the kart. Sorry it took so long I had other stuff to do.
lycsailor17
I looked through it
I looked at it, I couldn't find anything because of poor image quality. should I connect it to the carburetter or the throttle thing?:huh:
It works like this- If you wish to keep the engine's governor intact (the mechanism that limits RPM to 3600), then you connect to the "throttle thing"- The hand thottle, the large lever. If you remove the engine's governor, you would be removing all that too, and would have to connect directly to the throttle lever on the carburetor.
Given your "newness" (no insult intended), I would strongly suggest leaving the governor intact and just connecting to the hand throttle, for now at least.
lycsailor17
still confused
If I where to disconnect the hand throttle governor thing from the throttle on the carburetor, and used it that way, would I still be limited to 3600 RPM?
No, that's the point. You either stay governed to 3600 and connect to the hand throttle, or perform surgery on the INSIDE of the engine to remove the governor, and connect directly to the carb.
