Predator won't run off choke
falcon52
Depends on where ARCA race schedule is
Havin a rough time getting my predator 6.5 to run with the choke off. It is a pain to start and when it finally does start it only runs on choke. I can give it a little throttle and it will come up and start sputtering like normal but as soon as I take it off choke it dies. Here is a video and pic of the plug that shows it's running rish as sh!t. It has an aftermarket air filter but stock exhaust, stock jet to my knowleadge. I am thinking I just need to clean the carburetor again... Any other ideas though?
DaiSan76
Nixa, MO
Is the carb leaking air? I had a predator doing that and found out that the carb wasn't sealed against the manifold. Fixed that and it ran perfect.
jamyers
Buffalo Gap, TX
X2, I've had that issue often with the newer "laid-over-cylinder" engines. Seems the carb likes to get hung up on the sheetmetal air ducting.
falcon52
Well... I think I found the problem... And I'm kinda pissed. I bought this off a guy on craigslist. As I said, it started and ran before but I knew it wasn't right. However, it did fire the first pull when I bought it from him in my defense. Anyway, the plastic piece that the carb bolts to was cracked. And I know he did it because the nuts were **** near stripped out when I got to it and they didn't look quite right. For now I tried repairing it with the right stuff silicone until I can replace it. Anyone know where to buy one of these?
No, you havent. What you have linked is just a spacer, and you don't have a fuel pump (as far as I know). The plastic part that is cracked is called a carb insulator, and has little channels cut into it to facilitate air flow.
Do a google search for "carb insulator" and you will get what you need. They are really cheap
falcon52
Actually I DO have a fuel pump and I DID search for carb insulator and that is what came up in a thread on omb I believe.
http://www.oldminibikes.com/forum/honda-clone-predator-engines/73175-carb-insulator-plate.html
There was another thread on 4cyclekarting that I can't seem to locate at the moment but I did find it last night.
arc has them for 2.50 though
http://www.arcracing.com/servlet/the-Stock-OEM-Engine-Parts-cln-Predator-212cc/Categories
HOwever, from what I have found, that "channel" is just a vent for the bowl. if you look at it, it goes straight out to atmosphere anyway, which is what almost makes me think I have another problem because if it goes to atmosphere anyway, I don't understand why a crack would hurt it...
