Predator wont fire
l337murd3r
Indianapolis, Indiana
Ok so I went n bought a predator when I had it tore down I went ahead and removed the gov reassembled everything but now it won't fire up not sure what I didn't do right but I've checked the spark and fuel getting both has really good compression as I did not remove the piston heads or valves I fixed the timing on the crank and cam if anyone can give any advice please let me know if you need pics let me know what you want then of
KartFab
Dallas, TX
Go Kart Engine Governor Removal
the governor doesn't just limit max rpms
the governor opens the throttle butterfly automatically when starting the engine.
After removing the governor, you need to choke the engine, then manually hold the throttle butterfly open when starting the engine.
If everything else checks out *cough* kill switch *cough* then that could be one problem you overlooked. I had the kill switch issue once, felt so dumb.
Joe-405
Enjoying New Projects
U.S.A.
Could have a big air leak somewhere between carb or on the crankcase also
KartFab
Dallas, TX
Yeah I've checked the kill switch I've shot starting fluid in with throttle wide open still nothing happened
well then you must have assumed your timing or spark was fine was you really actually didn't have proper timing or spark. Engines are pretty simple. if you provide air, and a spark you are going to get it to do something. Just review the basics man. lets just go back to the basics, because I really think you may have glossed over something so try this to rule it out:
1) take out the spark plug, take off your air filter and keep the choke off and throttle butterfly open (you should see into the engine through the carb this way)
2) pour a tiny bit of gas in a spoon, or shot of carb cleaner right into the spark hole plug, replace plug and pull the cord, the engine should run for 1-2 seconds, or just start and run. If it just runs for a few seconds, you have a fuel delivery problem.
if you have no results, you aren't getting a spark when you should.
l337murd3r
To check the spark I took out the plug put it back in the wire laid it on the block and cranked it it was getting really good spark
As for the fuel I have put gas in where the plug goes and nothing happen so not sure what's going on with that it acted like it wanted to fire yesterday but it would never fire
Thanks for all the help so far
DirtyDamage
Westminster Colorado
I feel like your timing is off. Or you have an air leak somewhere as suggest above. I would check the timing first(Line up dots) then check. Then I would check valve lash, and adjust with feeler gauge. When you took off the crank case cover did you replace the gasket? You could have damaged it or not put in right and could be letting air into the crank case(not sure if that would keep engine from firing) And you say you "fixed the timing on the crank and cam" Really you shouldn't have taken out the cam. There are valves at the base of the cam and if you moved those out your valve lash is almost guaranteed to be off. Or your rockers aren't even on the springs.
IMGHO I would follow these easy steps;
Check Timing again(line up dots on cam and crank)
Check Valve's
Check Valve lash
Check Spark Plug Gap
Check Fuel Delivery
And lastly, if we've over looked this...if you didn't remove the low oil does the engine have enough oil?
Thats what I would do personally. I've fixed all my small engine problems from YouTube, funny how most people have the same problems as you with small engines.
Check Valve's
Check Valve lash
Check Fuel Delivery
This
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Gotta be the timing. Those little dots can be decieving on clones they are angle cut gears. Or first (cause it is easier) make sure your rockers are on the valves.
I just put an old engine together. Took it completely apart, head of,f cam, valves, pushrods. I put it all back together, without resetting valve lash or cleaning the carb. I got it to at least start and run 5 seconds. I will get a new carb and set the valve lash. My point is your engine should at least start.
Dazv
England
I had something similar happen to me recently and with help from this forum I fixed it. It was a problem with the valves, the valves had slipped off the arms was really obvious when I took the cover off.
