Yeah I've checked the kill switch I've shot starting fluid in with throttle wide open still nothing happened
well then you must have assumed your timing or spark was fine was you really actually didn't have proper timing or spark. Engines are pretty simple. if you provide air, and a spark you are going to get it to do something. Just review the basics man. lets just go back to the basics, because I really think you may have glossed over something so try this to rule it out:
1) take out the spark plug, take off your air filter and keep the choke off and throttle butterfly open (you should see into the engine through the carb this way)
2) pour a tiny bit of gas in a spoon, or shot of carb cleaner right into the spark hole plug, replace plug and pull the cord, the engine should run for 1-2 seconds, or just start and run. If it just runs for a few seconds, you have a fuel delivery problem.
if you have no results, you aren't getting a spark when you should.
