Predator upgrade kit
falcon52
Depends on where ARCA race schedule is
Haha not even close. The only thing they are giving you is an air filter and a jet which in my opinion is unnecessary with only a filter change. The head gasket is a joke because most predators come wit a .009" gasket anyway... The 18lb valve springs is a catastrophe waiting to happen because the only way they would take effect is if you removed the governor which would allow enough rpm to float the stock valve springs anyway. Then, if you do install the heavier springs, you end up sending a rod through the block or head and possibly exploding a flywheel... Be careful with that kit.
rmm727
Brookville, PA
Gonna have to disagree with the above to an extent. I basically have that kit except I bought it in pieces. 18lb springs are ok and do allow you to rev higher than you could with the stock springs. However, they are usually close to coil bind in most applications. You can't run them with a cam over .265 or so lift (or with ratio rockers) or you will coil bind and bend pushrods. The stock rod can live to 6k rpm.
I have 18lb springs in my gx160 clone with a NR racing .252 lift marine high torque winchboarding cam. I don't have coil bind and it revs to about 6200. It has been reliable for me for the past 2 or so years. Stock flywheel as wheel. I know when to left off. I do have the new PVL flywheel to install here pretty soon.
I would be concerned about the flywheel though. Its always a concern with a clone.
I'm with falcon on this one; that kit will do more harm than good...
The problem with kits is you get what they give you, not necessarily what you want/need. It may be a little more expensive but, the best way is to buy what you want individually. So, what do you want?
-Hi flow air filter
-Hi flow exhaust/header
-Stage 1, low end cam
-Remove governor
All that should set you back around $50 & give you an extra 2-3hp, maybe a bit more...
falcon52
Yeah, I don't know about 6k continuously on a stock rod. Not saying it can't be done at all, but I'd rather have a nice rod before turning that much (from a racers standpoint). And I see whay your saying with the valve springs, but I feel that stockers are your safety net if you don't have the flywheel and or rod to go with the governor removal. Then again, for $20 more than a new rod, you can buy an entire new predator lol, just be careful.
rmm727
Brookville, PA
I don't get the more harm than good statement. Granted the price could be a little better. NR Racing isn't the cheapest place to buy parts. I see little harm this kit could do. Its better than some kid putting in 26lb springs and either wiping the lobes off the cam or snapping the tips of the stems off the valves.
rmm727
Brookville, PA
Agree on the rod. Its nice to have and definitely ups reliability. BSP clones turn over 6k during races. Mine doesn't spend that much time in that range but it will go there just fine. Those trick or progressive 10.8lb springs have just about as much pressure as the 18's and are considered the "safety net" for them.
I'd rather have the valves bounce than the rod snap...
falcon52
Just like yours though, I've heard enough stories about rods popping in these than I've heard good. Just seems to me if you're gonna build it, build the thing. Kind of an all or nothing deal imo. Once you remove the governor, it's game on lol.
