Predator up grades?
predator
What mods would be the best to get. A cam for 40 $ or a 14cc head for 45$? i have a flywheel,.020 rod and adv timing keyway. just trying to figure out wich one would be the most usefull.
tundrabeagle3
Ca
I would go with a 14cc head its at least 2 hp bolted on and the most noticeable mod u can do , I wouldn't do 18 lb springs with out a billet rod and flywheel
predator
hey tundra, if i got a 14cc head would i need tobuy anything else or could i just switch every thing from the stock head over?
tundrabeagle3
Ca
you can switch over everything on the predator head over to the 14 cc head thats what I did
fowler
Bullsbrook West Aus
Id be going the high compression head first
But pushing too much compression can test a standard rod
If u can afford it I'd be fitting a billet rod now while the head is off
That allows an upping of rpm later if u wish to fit tougher springs
r_chez_08
Should be in the shop...
Cornwall, UK
Head, providing you already have a decent header and air filter.
Apparently you need to adapt the dowel holes for the predator, but it should be fairly self explanatory and be able to be done with some drill bits.
Maybe get some nice 1:1.3 stamped rockers in there too? They are much better bang for your buck than a new cam. Or diy some like I did. Weld up the rocker and existing push rod dimple, and drill some new holes closer to the pivot. Mine work perfectly!!!
tundrabeagle3
Ca
You don't need to drill out the dowel pins on the 14cc head most people run theirs with out the dowels including myself
