set2stun
Falling is just flying without ascension
I modified my predator by adding a top plate to it and a Honda carb which is longer than the factory carb. In adding the top plate i had to remove the factory throttle linkage because they both wouldn't fit. Additionally when i added the Honda carb i had to fabricate a longer governor arm. So right now i have a governor arm attached to the carb and governor lever. For some reason i can't figure out how to install the throttle cable without bypassing the governor. Can i just install the throttle cable via a spring to the governor lever? I have attached a video for demonstration. In the video the throttle cable is attached directly to the governor lever. When i pull on the throttle cable it causes the govenor lever to open the butterfly. I know there is a simple solution but my brain can't figure it out. I am honestly stumped.
http://youtu.be/s_-eaxkL6UI
