Slimmpd
Anyone know of a supplier for metric M10-1.25 fine adapters.
I need to fab up an extended oil drain for Honda and Chonda gx200 or Predator 212 engines.
It would be nice to be able to go from the metric fitting to an NPT threaded pipe or tube.
If not an adapter, then a source of 10mm hard, tubing or pipe. I've found a die but only have been able to find flexible tubing in the size I need.
On the Murray karts I have the engine deck is pretty big and when I pull the plug to drain the oil it makes a pretty big mess.
Just looking for an easier way to get this done.
back
