Hello everyone,
I have a Predator 212 engine. I had it on a Baja Mini with a centrifugal clutch. The engine is the hemi model and has maybe 4 hours on it. My son was driving it and it slide out from under him as he dumped it on the clutch side. When it hit the ground, the engine stalled. I tried to restart it, and the pull cord was very difficult to pull and would snatch back in my hand. I took the plug out and it turns over easily. I thought it was the timing key, but it was fine. I then went to check the valve lash and this is what I found:
I don't know how well you can see it, but the push rod is no longer supporting the rocker arm. I took the push rod out and it isn't bent. I'm by no means an expert on small engines and haven't taken the cover off of the crank/cam shaft to inspect. Is there a way to fix this? Is this an indication of a bent valve or bent crankshaft?
Any help would be appreciated.
