Predator head gasket question
Zombient
Junkyard Derelict
Waco, Texas
So I dun bought myself a new head gasket, since I've already got the engine torn apart anyways. I bought the BSP/Clone High Performance Head Gasket. It says that the pin holes may have to be modified to fit a hemi head?
Anyone know what they're talking about? I've not got home yet to take a look at the package, but that's just what the description said when I purchased it.
Also, since it's just a .10, will I have to adjust the valves? Run hotter gas? Etc. It's technically shaving the head.
Poboy kartman
Senior Moments Member
White Settlement Texas
I have no idea, but generally speaking, pin holes are holes that go over pins that locate the head and gasket in the correct alignment with the block.
EDIT: You will have to reset the valve lash.
