Predator Engine 212cc problems
jet7781
California
So I bought an old yerf dog go kart. The engine was really loud so I swapped it out for Predator Engine 212cc. It originally had a Tecumseh power sport. So I went for a test drive and it was very slow I used to get at least 30-35 and now it only goes about 15-20 mph. What could be the problem?
Could it be a gear ratio problem? I'm new to this. The go kart has a torque converter.
What HP was the Tecumseh? Are you sure you connected the throttle linkage correctly on the new engine. When you push the pedal, is the cable actually opening up the engine all the way. You might think you have your foot all the way down on the pedal, but the engine is only revving halfway. while the engine is off, have someone push the pedal all the way to the floor. You stand at the engine and see if the engine throttle is opened all the way. If not, adjust the cable accordingly
jet7781
California
The Tecumseh was 6.5 hp(or atleast I think because it only said 212cc) Ive tested the throttle cable and it does open fully. By the way thank you for your help!(i really need it.)
Half-breeder
"Edit" button removed
Only thing I can think is either... were the weights for the TC put back in the proper direction... may need a cleaning anyways? ... and I suppose its 'possible' that the Tecumseh's governor was removed/bypassed(if sucha thing is possible on a Tecumseh).
... my .02 scents.
jet7781
California
Could it be the Tecumseh was more torquey (dont know if this is a word). And no the governor was not removed.
2SlickNick
American Minibikes @ FB
Mesa, AZ.
Could you post pics of the set up? That may help us, help you. Get a few different angles of the TC.
Did you take the TC apart when doing the swap? If you don't have a backing plate for the TC, are you sure that the driven and driver are at the right distance from each other for the belt that you have?
Half-breeder
OK... IMO... that belt NEEDS replacing... that's #1 off tops (a new belt is 2x yours width and is asymmetrical... yours looks to be a V-belt... V-belt=20series)! Next, that driven looks alil worn (belt isnt suppose to sit so low in the valley at idle/rest). Have you lubed it (taken it FULLY apart and lubed the slide/race)? Suppose its possible the spring is worn (but Im suspecting not preloaded...)
... driver 'looks' proper, but one can only tell w/ the clamshell off.
