Predator cams
The differences are, lift, duration, centerline, overlap and lobe profile. Yes it is possible to get a lope just look for a cam with narrow overlap. for instance you have 2 cams 1 with 112 degrees of overlap and 1 with 106. The one with 106 will idle rougher and lopier. There is quite a science to choosing the right camshaft, you need to have everything working together including drive train (shift points) gearing, carburetion and intended use. Hope this confuses you. :stir:
Zombient
Junkyard Derelict
Waco, Texas
:lolgoku:Very confused! Thanks!
I think I need to layout which parts I'm going to be using. Probably the right carb.
