Not a chance. Springs are an integral part of gov. Everything is there for a GOOD reason.As long as i dont mess with gears in the engine case, will the engine rpms still be governed?
Pull 'em off and find out!What will happen if I do remove the springs to the carb? Will the engine not run a idlle right?
This about covers it. Without ALL parts intact and properly adjusted, the system will not work. Either leave it be, or remove the entire system.Springs are an integral part of gov. Everything is there for a GOOD reason.
