awmayhall
Hey guys, I am new to this forum here so nice meeting you all!
As the title suggests I am currently working on a Predator 420cc build packed full of upgrades. I just picked up this engine at the local harbor freight near Saint Peters MO, and started tearing into it.
I've already got a new ARC 6272 billet rod and ARC 6672 billet flywheel. Governer has been removed already and I've got a new Mikuni Flatslide, 34 mm carburetor and manifold on order. Can't wait for those to get in!
Whats left to do is decided on a replacement upgraded camshaft and what specs to mill my head to and the various upgrades that come with that. I am primary building this motor for some serious low end torque. So I am probably going to shoot for a compression ration close to 10-11:1 using a 280 series cam. I am open to suggestions though!
Now when I first unboxed the engine I immediately noticed there have been some changes that I am a bit unfamiliar with. First and foremost the predator head for the 420cc has changed dramatically. I took it off and I have uploaded some pictures showing left the 2014 Predator 420cc head and right the 2012 predator 420cc head.
You can see for yourselves that the two heads are completely different. Has anyone seen this on other 420cc Predators? I am interested to hear what you guys have to say on this.
Also that stock intake valve is 38mm diameter?! My 2012 stock is 36mm. So why the change? Hopefully those pictures are high res enough, but the intake valve doesn't have a whole lot of clearance to the side and bottom of the head. So I guess milling this head down on my Bridgeport won't be all that worthwhile....
I have yet to measure the volume of the head, but it just looks smaller that that of the 2012 head. The manual says stock compression ratio is 8:1. I am a bit worried that they added material to the top of the cylinder making the distance from TDC to the mating half of the head larger. Thoughts?
